94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
1996 PSD downpipe upgrade help
Old Dec 28, 2010 | 06:18 PM
BlackOut96's Avatar
Default 1996 PSD downpipe upgrade help
My 96 PSD's downpipe leaks & I am lookin at aftermarket one's and am wonderin which one is best and easiest to install I dont want to have to smash my firewall in much and am on a limited budget. Any sugesstions?
Old Dec 28, 2010 | 08:47 PM
cowboyjohnson's Avatar
your not tellin us that your downpipe is still stock! . . . are you?
Old Dec 29, 2010 | 02:14 AM
BlackOut96's Avatar
my downpipe is stock and crap
Old Dec 29, 2010 | 07:28 AM
ccarrier's Avatar
mbrp or diamond eye 3in dp can be had less then 100 bucks... you will need to modify your firewall either way
Old Dec 29, 2010 | 09:45 PM
95powersmoker's Avatar
Firewall modification is a must on our trucks. Either get yourself a Portapower and wedge a 2x4 on the tranny and let the power tool do its thing. Or saddle up, get yourself a crow bar and do work!
Old Dec 31, 2010 | 10:43 PM
my buddy was supposed to help me with mine but he copped out. so the crowbar and i became good buddies
Old Jan 1, 2011 | 10:54 PM
95-SimpsonOBS's Avatar
portapower is the only way to go on the firewall. firewall modification isnt as bad as you think it is, just be sure when you do it that you smash it far enough in and away from the down pipe, otherwise it vibrates on the firewall, i speak from experience here, take the extra time to smash the firewall in otherwise youll be tearing the DP out to do more "body modifiacation" good luck with it
Old Jan 2, 2011 | 12:46 AM
DirtyMo's Avatar
I got the diamond eye turbo back set up. The down pipe has the flange at the bottom that would connect to the stock cat. I'm not sure if you bought just the down pipe if it would come the same way. MBRP down pipe is a straight 3" w/out flange.
Old Jan 21, 2011 | 02:02 PM
BlackOut96's Avatar
I got the Diamond Eye off ebay it wasnt bad & I just ended up using a crowbar which got er done it sounds a ton better and way more deep.
Old Jan 24, 2011 | 07:02 PM
RattleBomb7.3's Avatar
about to do the same, i see cobb's has a diamondeye for $80 aluminized. I hate that uterus shaped stock flat pipe!! about how far did you have to clearance the firewall to do it?? i got plenty of prybars
