Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
Turning up '91 Mits/Fuso?
Old Dec 27, 2010 | 08:25 PM
TurboBu's Avatar
Default Turning up '91 Mits/Fuso?
Just bought a 4cly/auto Mitsubishi Fuso 437 box truck w/only 85,000 miles. I don't want a hotrod and it doesn't run bad but we have some pretty gnarly hills around here and it needs a little boost anyone turned up 1 of these?
Old Dec 27, 2010 | 10:34 PM
spoolinaround's Avatar
the Jatco trans is the weak link, they are only good for about 150 hp max the 437 has the same motor as in mine, it should be 113 hp yet they are capable of over 200hp with just turning the fuel up, there is a external cam on the side of the pump with a bolt to limit fuel, back the bolt out and turn the cam towards the bolt to add fuel, remove the bolt and turn all the way for full fueling and about 220 hp/380 ft lbs of torque (what mine made on the dyno)
Old Dec 27, 2010 | 10:36 PM
TurboBu's Avatar
dont have a pyrometer on it yet, do you have to be careful w/egt with the screw all the way out?
moparisthebest
23
Oct 15, 2015 12:13 PM
Alaskabound
Aug 20, 2015 07:00 PM
jmerriman17
Nov 10, 2014 02:44 PM
wyoranch
Oct 28, 2014 08:23 AM
