1998.5 Cummins 24v problems HELP
Old Dec 21, 2010 | 05:24 PM
aaronmoore's Avatar
Default 1998.5 Cummins 24v problems HELP
hey guys recently been having problems with truck ... truck started being hard to start so installed new airtex lift pump and the lift pump is not cycling with key on or bump start but every now and then it will but runs good when started, no codes, only modification is edge programmer .. any help would be appreciated .. Thanks
Old Dec 21, 2010 | 07:40 PM
DanLowe's Avatar
Take the edge off and see if problem is still there. If it is, check all the relays...go from there...
Good Luck, keep us posted
Old Dec 21, 2010 | 07:45 PM
cummin_un_glued's Avatar
FormerVendor
take the airtex pump off and put a carter back on it or a airdog lift pump...i have had ALOT of problems with the airtex pumps causing a hard start condition, i been putting the oem replacement carter pumps on most of them and it fixes them...best we can figure out after talking to bosch is that the cummins ecm reads fuel pressure by the amp draw on the pump circuit and the airtex pumps arnt showing the correct amperage so the ecm see's it as too high of a pressure and the ecm tells the injection pump not to fire...have also had this problem with the FASS DDRP pumps and i dont know if they have corrected the problem or not...i have a regular fass on our 01 truck and it works perfect just seems to be the DDRP's that had the problem
Old Dec 22, 2010 | 07:07 PM
aaronmoore's Avatar
yea i took it off and still no change i checked relays i was having same problem with the carter just not as often but still very frequent.
but ill pick up a new carter in morning and see what happens thanks for the replies.
Installed the Carter stock pump, no more issues..Thanks for your help, turns out Airtex is junk and definitely would not recommend it for anyone!!!
Last edited by aaronmoore; Dec 22, 2010 at 07:07 PM. Reason: Automerged Doublepost
Old Dec 22, 2010 | 09:45 PM
biged681985's Avatar
since ive started working for cummin_un_glued, i bet ive pulled 5 or 6 airtex pumps off that was causing hard starts. thats been less than 6 months
glad ya got it fixed
Old Dec 23, 2010 | 11:01 AM
FormerVendor
sounds like your stock carter was going out and causing the problem then the new airtex was causing the same effect but in a different way...glad the new carter fixed it!
gh0stman
Price Quote - Request A Price
Sep 9, 2015 12:12 PM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
mt grizzly
Diesel Engine Conversions
Dec 31, 2014 12:13 AM
Downd19
Dec 30, 2014 02:49 PM
