More Power?
Old Dec 19, 2010 | 12:02 PM
[[ChRiS]]'s Avatar
Default More Power?
I have a 96 psd and was wondering if there was any cheap way to gain a little extra power? right now i have a dp tuner, straight pipe, intake, and waiting on my turbo to come back with a bd compressor wheel. any help is good.
thanks chris
Old Dec 19, 2010 | 01:22 PM
PHPDiesel's Avatar
Sponsor
Without higher capacity injectors, you're out of luck.
Old Dec 19, 2010 | 07:08 PM
OceanDiesel's Avatar
In my '96 I had stacks and intake, no chip or tuner, with a 5 speed. I put in Stage I injectors and that truck came to life. PHP is right, injectors will do the trick, especially with what you've already done.
Old Dec 20, 2010 | 02:47 AM
[[ChRiS]]'s Avatar
yeah.... it would be nice if i had the cash. college kid right now. if rons turbo shop in utah ever sends my turbo back to me( 3 weeks now) from getting balanced i plan on shimming the fpr will that help any?
what about just replacing the nozzles? does that help?
Old Dec 20, 2010 | 02:57 AM
prison's Avatar
yes replacing the nozzles will help as long as your injectors are good which i'm assuming they are
Old Dec 20, 2010 | 09:33 AM
[[ChRiS]]'s Avatar
where can i get a good set of nozzles?
Old Dec 20, 2010 | 02:12 PM
prison's Avatar
post on this site requesting a quote. the vendors will p.m. u with prices. that's the easiest way
Old Dec 20, 2010 | 05:13 PM
PHPDiesel's Avatar
Sponsor
Don't waste your time with larger nozzles on a stock AA injector.
The issue with AA injectors is not the nozzle size....it is the limited fuel capacity. If you put larger nozzles on your stock 90cc injectors, you will have wasted a ton of time and money because the injectors will empty almost instantly and you will be left with no "push" on top of the piston after TDC.
If a vendor will actually sell you larger nozzles for a stock AA injector, that person needs to check their conscience.
Old Dec 20, 2010 | 06:54 PM
redneckabbott's Avatar
If you can go without your truck for alittle while, send your injectors off to rosewood diesel and have them built to flow more. It's cheaper than buying reman injectors
Old Dec 21, 2010 | 11:37 PM
[[ChRiS]]'s Avatar
any price on how much that would cost? im new to all this diesel stuff. where is rosewood at? im from indiana
