injectors
Old Dec 18, 2010 | 06:20 PM
articfox's Avatar
Default injectors
i was wondering how hard it will be to install injectors in my 2001 f250
Old Dec 18, 2010 | 09:56 PM
OceanDiesel's Avatar
It's not hard. I swapped mine out in November. I took my time, painted the IC tubes, replaced GP's, installed new dipstick, cleaned the radiator, replaced the water pump, put in Swamp's tuner, and tested my injector harness...all in 8-9 hours. But I've done it before, so as long as you're not trying to rush, you'll be fine.
Old Dec 19, 2010 | 12:53 AM
99stackedpowerstroke's Avatar
its not hard, there right under vc, just make sure your careful when your putting the orings on new ones, and careful when installing them so you dont cut or rip the orings, but if you have the money, and you want to, install new glowplugs since you have it all apart already
Old Dec 19, 2010 | 10:07 AM
coper's Avatar
Do you already have them
Old Dec 23, 2010 | 06:02 PM
articfox's Avatar
no i dont have them yet i was just wondering how hard it was so if i got some i could put them in my self
Old Dec 23, 2010 | 06:31 PM
Lange503's Avatar
its not too bad, driver side is easy, soooo start on the passanger, you'll need an extenstion and a wobbly to get the middle ones, thats the hardest part
Old Dec 24, 2010 | 04:44 AM
Jeff Davis's Avatar
there is info on the internet on how to keep from getting hydrostatic lock in your motor when changing injectors make sure to follow these guide lines on how to remove the oil from the cylindars before installing and cranking over the motor. anyone please feel free to correct me on this practice if exuburant and unnessesary but I did follow these gudelines when changing mine because if what they say is true it will cost a fortune and I felt that it is always better to be safe than sorry.
Old Dec 24, 2010 | 04:15 PM
Lange503's Avatar
CSIPSD did i write up on it i think? but yeah just follow those directions step by step and you'll be fine
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
