Blazer 89 cummins 93 motor mounts???
Old Dec 17, 2010 | 12:47 AM
cumminsblazer's Avatar
Default Blazer 89 cummins 93 motor mounts???
I'm finally about to start I had to dig up parts before I started but my question is motor mounts ya I know there are kits but haven't found ones I like and really wouldn't mind building a set up but but what mounts would be better then the 93 junk ones that split all the time
Old Dec 21, 2010 | 10:14 PM
crewcab59's Avatar
I bought mine from fordcummins.com they mount to the block and mount in clam style chevy bushings with after market bushings and it places the motor right where you need it. there are alot of other stuff you need to do also, build new cross member, notch frame for a/c pump and cut down front p/s pump suport,to clear bottom pully (simple really) so just read on. good luck
Old Dec 22, 2010 | 03:33 AM
I found what I'm gonna end up running I found out that early ford 460 mounts are way over kill very beefy so that's what I'm gonna run I will get pics when I get started
Shun70
Sep 21, 2015 01:39 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
