Killer Dowel Pin...In 1st Gens.
Old Nov 14, 2007 | 07:32 PM
DieselfreakMI's Avatar
Default Killer Dowel Pin...In 1st Gens.
Do you 1st gens. have the same issue as the 2nd gens. with the dowel pin following out of position? And the same repair kit could work for both engines, right?
I just picked up a 1992 dodge ram 250 4x4 auto, and i dont want to lose half the value of the truck because of a cheap little pin.
Old Nov 14, 2007 | 08:25 PM
LOGANSTANFORTH's Avatar
yes, the same as the P-pump trucks.
Old Nov 14, 2007 | 09:34 PM
Begle1's Avatar
But the pins are a relatively rare problem on first gens. Still possible, but not as likely. I hear that timing case bolts do damage more often than the pin.
Old Nov 15, 2007 | 11:30 AM
DBogo's Avatar
the repair kit is different for the 89-93 trucks, then the 94-98.5 the kit is actually the same for the 24v's as it is the first gens
http://www.tstproducts.com/index.asp...ROD&ProdID=189
Old Nov 15, 2007 | 05:28 PM
alright...thanks
Old Nov 25, 2007 | 02:14 PM
ez_lle71's Avatar
I did the kdp repair on my dad's 95' the same day as my 92'. His was maybe 1/8 inch sticking out of the hole. Mine was deep in the hole. The 95' was flat around the hole where the 92' had a boss cast around the hole which i think helps to hold the dowel pin in. Just my experience.
ez
Old Nov 26, 2007 | 08:37 PM
MUDDY's Avatar
1st gens didnt have locktite on the case bolts. need to remove em one by one and clean and red locktite em.
the tab is different for 1gen than for 2nd gen. hbowers is the only one who makes the tab kits for the 1st genners.
http://www.idahobombersforum.com/vb/...ead.php?t=1009
Old Dec 6, 2007 | 08:59 PM
I would imagine you can make the retainer washer and bolts, generally are available at the hardware store...Im going to just get the seals I need then do it without a kit.
Old Dec 7, 2007 | 05:19 AM
BD has the kit for like 89 bucks with new case seal and crank seal
Old Dec 7, 2007 | 05:35 AM
ez_lle71's Avatar
Just get the seal and case gasket from cummins and make your own retaining washer. I peened around the the dowel pin and made a washer out of coat hanger wire. Worked great. I did my dad's 95' and my 92' the same day. There are some suttle differences.
ez
