7.3 wont start need help please
Old Dec 5, 2010 | 07:06 PM
jfleezy's Avatar
Default 7.3 wont start need help please
i have an 02 psd. I just had the cam mapping sensor 2 days ago. I was driving it and the trc just lost enginepower. I rolled to the side of the road, stopped and tried to start again andthe wts light was on and stayed on i could crank it but wont fire. I took it to the dealer they said i hassomething to do with the injectors. I get the 1211?(cant rember) sometimes when i get on it but then i just clear it. but reading other post i dunno. I just wanna make sure its not something simple b4 i pay a lot at a dealer. thanks
Old Dec 5, 2010 | 08:11 PM
99stackedpowerstroke's Avatar
https://www.dieselbombers.com/ford-p...ble-codes.html run your codes and check here, its a list of of codes thrown by 7.3s, this says ur icp which is real easy ta replace,
Old Dec 5, 2010 | 08:28 PM
jfleezy's Avatar
yea i hooked up myedge programmer up to it and it wouldnt read any codes. I just usually clearedit and it always worked fine. Then wy would the wait to start light stay on. thanks for the reply also.
Old Dec 5, 2010 | 08:48 PM
it never shuts off?
Old Dec 5, 2010 | 08:53 PM
jfleezy's Avatar
no i let it stay on for like 5 mins too. i disconnected the batteries too to see if i could getthe codes too but nothin
Old Dec 5, 2010 | 10:53 PM
CSIPSD's Avatar
Then you have an issue with your CPS, ICP sensor, IPR or IDM... Could be many things, but without a scanner its near impossable to tell.
Old Dec 10, 2010 | 07:10 PM
chucks 7.3 f-350's Avatar
check your ipr cylinoid for resistance between conecters
Old Dec 10, 2010 | 07:49 PM
espowerstroke's Avatar
I have the 02 f350 powerstoke which is very hard to start in the cold but other wise awesome truck but i had a problem similar to the one you are having and my high speed oil injection pump was goin out after i replaced it everything cleared
Old Dec 10, 2010 | 11:33 PM
CSIPSD's Avatar
High Pressure, not high speed...
Dcbb93
Nov 30, 2015 10:18 AM
Bigredpowerstroke
Aug 14, 2015 10:31 AM
Domrig13
Dec 12, 2014 01:24 PM
custom7.3
Nov 23, 2014 10:44 PM
SHIFTNGEARS
Oct 30, 2014 05:40 PM
