Wiring for a 94 - 97 F350 Cummins swap
Old Dec 3, 2010 | 05:20 PM
btp76's Avatar
Default Wiring for a 94 - 97 F350 Cummins swap
I'm in the midst of converting a 96 F350 powerstroke to a 12v cummins. I know the cummins only takes a few wires to run. What have you guys done about the rest of the wiring in the truck. In a perfect world I'd be able to eliminate the ECM under the hood, but I think a few critical functions still run through it - cruise control for one. I have the drive by wire harness and the auto overdrive plug hanging under the dash. And will wind up with several unused wiring on the engine harness.
Will the lack of all the computer functions trip the check engine light?
I have to replace my loose dash bezel. I have another out of a gas truck. I'd like to mount my pyro and boost gauges in the upper right where the diesel specific idiot lights would go. Is there a good reason to keep the lights, and will they even still work when I'm done?
Old Dec 7, 2010 | 11:50 PM
EasternAggie's Avatar
In my truck, I cut all the wires on the engine wiring harness and am only using 3 of the original wires right now. Two for the oil pressure and water temp senders/gauges, and another for a key on hot wire. I have the rest just kinda hangin there, but sealed off.
Old Dec 9, 2010 | 10:15 PM
Screamin' Metal's Avatar
What EasternAggie said! Only needs 4 wires to run including Alt. wires....
Old Dec 14, 2010 | 09:23 AM
DangerMan's Avatar
Default BeenThere Done That.
Ive Got a 99 F250 that I swapped, its not hard. I 2nd the two answers above. Locate a hot Key Wire... Like EFI Hot Wire, plug that into your Pump. As Far a Cruise...... It Can get a bit tricky. and you might want to consult Destroked, or my buddy Jason over at Fordcummins.com to figure out how to make it work.
Everthing else is simple. If Ya dont need it, JUNK it!! If Ya Need It... LEAVE IT!!
If you have any ?? Just ask. Ive done all of my swap the HARD WAY...
Old Oct 31, 2011 | 03:03 AM
97DieselVT's Avatar
I am seriously considering putting a 93 cummins into my 97 F350 and I was just wondering if you had any advice concerning running the fuel tanks with electronic senders with the mechanical ve pumped cummins. Also, what did you do to make the existing ford gauges/tachometer work or did you replace them with analog gauges? Any help would be greatly appreciated.
Old Nov 3, 2011 | 07:21 PM
timdale's Avatar
As far as the check engine light, might as well pull the bulb like I did cause it won't ever go out! (but it won't hurt anything!)
Old Nov 4, 2011 | 06:14 PM
Thats what Im about to do, mines been starin at me for a year now
DieselDan370
Aug 23, 2016 02:24 PM
yzrider250
Aug 10, 2015 11:33 AM
atreefunk
For Sale
Apr 13, 2015 10:57 PM
mcclusk
Feb 21, 2015 09:50 PM
Andy81
Jan 28, 2015 02:53 PM
