Oiling Of Ford Dodge And GM Trannys
GM & Dodge NV4500 5 spd Castrol SyntorqLT 75w85 4 qts
Dodge NV5600 6 spd Texaco STF or Pennzoil Synchromesh 9.5 pts
Dodge Getrag G360 spd 5w30 (Synthetic preferred w/Diesel) 6.8pts
Ford ZF42 & ZF47 5spd Synthetic Mercon/Dexron III 3.4-3.8 qts
Ford ZF-650 6spd Mercon or Synthetic Mercon/DexronIII 6.4 qts w/cooler
Ford Mazda M50D LD 5 spd Mercon/Dexron III 7.6 pts
GM ZF S6-650 6 spd GM Synthetic 12378515
On a related note, I changed my Dodge's auto tranny cover out for a mag-hytec double deep pan recently. I was told, and confirmed on various websites that I would need 15 quarts to do this. In reality, I only put in 11, and yes, it really was the double deep pan.
The first two listed just caught my attention as they were brand specific. For the NV4500, our product is the Synthetic Manual Transmission and Transaxle
Gear Lube 75W-90 API GL-4 (MTG).
For the NV5600 it's Synthetic Manual Synchromesh Transmission Fluid (MTF) SAE 5W-30,
For the GM S6-650, our Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD) will work.
As for the mercron and dexron, the ATF wil work for any of those.
Thanks for letting me expand the options
Did you only replace the pan? If so you had quite a bit of tranny fluid left in the converter. Check the level per dodges process and if it is in the green... Run It!!!
WHAT??? You mean your supposted to put oil in these things? That explains why my last truck would only go in reverse after 200K.
For those running the Allison use either Torque Drive from Amsoil or TranSynd from Allison. Both have the same chemical properties, extend the drain intervals, and help give more clutch holding power.
