Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
Brazillian Ford 6.6 Bus Engine
Old 11-11-2007, 11:23 PM
cummin_un_glued's Avatar
FormerVendor
Default Brazillian Ford 6.6 Bus Engine
any body know what injectors a guy might put in one of these as a upgrade? also what about the injection pump...it is a m-w bosch pump i've heard...other then turnin it up anybody know of maybe a different pump that could be put on?......would parts from a 7.8 work?
this is the engine..... http://www.usdieselparts.com/moreinf...10&CFTOKEN=687
Old 11-12-2007, 06:46 PM
saab9k's Avatar
I would say it is in family with a tractor engine, i sell water pumps there will fit.
Front mounting bolt holes look like it may fit a 8220 - 8230 tractor
Is it coming with a Simms pump or cav ??
Above top transmission bolt hole, there is a place to mount the hydraulic pump for the remotes on a tractor
Old 11-17-2007, 09:47 PM
nevrenufhp's Avatar
An easy swap over would be an A, or P-pump from a 7.8. They both can use Cummins 5.9 hop up parts like gov springs & delivery valves. For injectors, many of the tractor pullin companies can make you a set built to your needs. It would make a neat pickup engine, since you would have a Ford logo on the valve cover.
burndiesel
10
02-07-2023 01:15 AM
01-31-2015 03:10 AM
11-04-2014 01:30 PM
10-14-2014 08:40 AM
Quick Reply: Brazillian Ford 6.6 Bus Engine
