Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
international 4700 t444e NO START
Old Nov 24, 2010 | 11:28 AM
autofabricator's Avatar
Default international 4700 t444e NO START
ok im having a hard time here. i have a 96 international 4700 rollback with the navistar t444e engine. my father said it died then started and ran, then died and wouldnt run. i have been dickin with it and cant figure it out. it has crystal clean fuel, new fuel filter, cleaned the pre-filter screen, new cam sensor, and i tried an idm out of an f-350. it cranks nice and fast and has 40 to 50 psi of fuel pressure. i pulled the icp sensor out and turned it over and it is pumping oil, im just not sure how to test how much, or how to test if the sensor is working. also, any idea how to test if the idm is geting power or of the injectors are getting any kind of signal? i dont see any smoke of any color while cranking. im baffled. any input would be great. thanks
Old Nov 24, 2010 | 11:33 AM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
have you tried to see if it will start on starting fluid.
Old Nov 24, 2010 | 11:42 AM
ya it will run on starting fluid but thats it. when the spray stops, the fire stops. i hate using that stuff but it i had to try it
Old Nov 24, 2010 | 08:49 PM
white93's Avatar
We a have a fleet of these at work and its a regular problem. We have a scan tool to read icp but if you don't this method works too.
When cranking you should hear the injectors making a clicking noise. If you don't hear them you more than likely have a stuck ipr or oil got the best of the wires going to it and it needs those wire replaced. IHC sells a kit if thats the case
Old Nov 25, 2010 | 05:16 PM
farmingsthelife's Avatar
if its bad icp it will crank and act like it wants to start, maybe even barely rough run for 30 seconds or so, then die.
Old Nov 29, 2010 | 01:19 PM
whats ipr? and how do i know it has oil pressure for sure? i think i might just throw an icp sensor in it just to eliminate that. i thought about the oil getting the best of the wires and it seems a lil unlikely that it would happen to both sides. i am almost positive the injectors do not click.
Old Nov 29, 2010 | 01:40 PM
white93's Avatar
The ipr (injector pressure regulator) is a little valve that controls the pressure going to the oil rails in the cylinder heads. It resides down in the valley towards the front of the engine. Over time it tends to get clogged up with debris and can get stuck closed causing low power or no start conditions. I would replace the ipr and icp and it should start,worst case senario it could need a hpop.
Heres a site that kinda show what im rambling about.
http://www.fordtechservice.dealercon...iagnostics.pdf
Old Nov 29, 2010 | 03:19 PM
that would suck, abotu how much are reman HPOPS going for
Old Nov 29, 2010 | 07:48 PM
white93's Avatar
A reman is about 1100 from International. They usually don't go bad unless you never change the oil or get the oil contaminated with lots of fuel or water.
Old Nov 30, 2010 | 01:07 PM
ok thanks. im gonna order up the ipr and icp today and hopefully get them installed in the next couple days.is there any cleaning to the old ipr? or strictly just replace? im hoping it doesnt need a HPOP.. thanks for all your help. i will keep you updated
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
ayvahaiden
Nov 3, 2014 07:30 AM
