View Poll Results: ZF-5 or NV 4500
ZF-5
33.33%
NV 4500
8
66.67%
Voters: 12. You may not vote on this poll
which tranny ZF 5 or NV4500?
Old Nov 17, 2010 | 07:00 PM
cummins bronco's Avatar
Default which tranny ZF 5 or NV4500?
so i am running a small block ZF-5 now in my Bronco and the clutch is just too darn small (its a 10 inch South bend ceramic) and it slips, not bad but i can spin it.
so i need a bigger clutch which means i need a bigger bellhousing, which means i need to change my tranny.
just want some opinions on both.
bonus to the Powerstroke ZF is no problem mating it to my NP205 transfercase, downside is i need to buy a new adaptor plate.
NV is easy and cheaper to get the adaptor plate but i will have to modify my 205 using dodge input shaft to make it work.
Old Nov 17, 2010 | 08:19 PM
cummins95's Avatar
i'd go with the nv4500. they are extremely tough, as long as you fix 5th gear and put the right fluid in it.
idk if its a common problem with the zf5 but i know of a 97 powerstroke that keeps breaking the aluminum tailshaft housing... could just be that he's an idiot n beats the snot out of it
Old Nov 18, 2010 | 12:14 PM
EasternAggie's Avatar
I like ZF5 but the NV4500 just seems more tried and true.
Old Nov 23, 2010 | 06:41 PM
no one else has an opinion?
Old Nov 23, 2010 | 07:46 PM
47Ford - 1.5Ton's Avatar
I have an 11" LUK clutch on my small block ZF.....
Hmmmmm
Old Nov 24, 2010 | 05:31 PM
Adaptor plates are expensive..... just my opinion I would stick with the NV4500. How hard will it be to modify the NP205?
Old Nov 24, 2010 | 06:18 PM
yeah i think i am leaning toward the NV i need to get my hands on a dodge np 205 and see what it will take to put the input shaft into the Ford 205.
Old Nov 25, 2010 | 06:14 AM
Sweet dude. Hope it works out for ya
Old Dec 16, 2010 | 11:44 PM
cumminsblazer's Avatar
I was just looking that up about the 205 and according to new procces ford 205 has a 6 bolt pattern just like the 205 that comes behind the getrag and ford 205 has the larger front bearing just like the dodge the down side of the swap that I found was the 29 spline input shaft kits that I was finding were $600+ hope that can help your swap
Old Dec 26, 2010 | 07:42 PM
rab475's Avatar
the zf will be cheaper and just as tough or better than the nv4500. why not use the zf 6 speed
