truck stays running
Old Nov 15, 2010 | 07:30 PM
rookieowner's Avatar
Default truck stays running
I have an 02 f250 diesel after turning key off truck it keeps running for about 10 sec.
at idle, its dies after 10 sec or if I give it throttle any ideas on the problem? also engine light came on with code 1690 wgs so replaced after testing. it was good for about a week
then same code any help?
Old Nov 16, 2010 | 03:32 PM
Lange503's Avatar
does it have a turbo timer on it?
Old Nov 16, 2010 | 04:06 PM
adub12valve's Avatar
or your fuel shutoff solenoid?
Old Nov 16, 2010 | 04:31 PM
prison's Avatar
shutoff solenoid shouldn't do the ten seconds then go off. i'm gonna say turbo timer
Old Nov 16, 2010 | 07:04 PM
no turbo timer on truck, thanks
Old Nov 17, 2010 | 02:32 PM
Lange503's Avatar
does it have a remote start installed? if its not that then i have no idea what else it could be??
Old Nov 18, 2010 | 07:34 AM
85_305's Avatar
Being Evaluated
^thats a good one! I wonder if there is indeed a remote starter installed.
Old Nov 18, 2010 | 07:06 PM
no remote starter may be computer problem?
Old Nov 18, 2010 | 07:36 PM
CSIPSD's Avatar
Can you get a video of this? I have been avoiding this thread for a few days because I have no idea what could cause this... When you turn the key off the PCM and IDM stop getting power, once that happens, no more fuel...
Only thing I can think of is leaking oil or fuel into the cylinders, but hitting the throttle should have no effect on this...
Kinda got me stumped!
Old Nov 18, 2010 | 07:55 PM
CowboyDiesel's Avatar
Does the rig have PATS?
