hydraulic pump mount
Old Nov 13, 2010 | 06:12 PM
tltruckparts's Avatar
Default hydraulic pump mount
hey guys i just got done swapping out a 460 for a 7.3l powerstroke in my tow truck. its a 1997 f450 with a 7.3 diesel. the only thing i have yet to figure out is to mount the hydraulic pump. its belt driven on the engine. anyone have any ideas on how to mount it? it used a pulley that takes 2 normal belts (non serpentine) but the truck is a serpentine setup. anyone ever mount hydraulic pumps on one? pictures are helpful. thanks
Old Nov 14, 2010 | 01:39 AM
fordornothing's Avatar
what about geting a pump to sit where the a/c pump goes? i know they are out there i just don't know who makes them. The Original Flatbed Bale Handler last i checked. for the "hydra bed" they use a belt driven hydraulic pump.
Old Nov 14, 2010 | 10:02 AM
i can put it where the ac goes but i still need the ac its way too hot here living in a truck without ac all day. and i have a place to mount the pump.but all the clutch pto pumps use a dual v groove 1/2" belt pulley. the truck is a serpentine. so i need to find a combination pulley that can still run a serpentine on the crank or another pulley but have v grooves in front of the serp belt
Old Nov 14, 2010 | 08:17 PM
where is a place to mount the pump? or put an electric vacume pump like what the "superduty's" have and make up a bracket for the hydraulic pump.
Old Nov 14, 2010 | 10:08 PM
that still doesnt achieve what im trying to explain. the truck runs a serpentine and the hydraulic pump runs dual v grooves. i cant just throw the hydraulic pump in there and have the vgroove pulley work with a serpentine setup
Old Nov 15, 2010 | 11:33 AM
ok i see what your saying. can you put a different pully on the pump? or get a custom pully made up for the power steering pump so it will have the serp an a double v grove?
Old Nov 15, 2010 | 10:09 PM
i found a pulley on broncoair.com for the powersteering pulley its a serpentine and a single v groove but that should be fine if that belt slips then i got another problem but it shouldnt, most people go the same route with an air compressor setup
Old Nov 17, 2010 | 10:11 PM
that should work.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
moneypitk5
Feb 12, 2015 11:01 AM
B.k. Smith
10
Jan 7, 2015 02:29 PM
