'02 Making some rattle noise under load ONLY!!
Old Nov 9, 2010 | 12:27 PM
Snowman's Avatar
MR.3K
Default '02 Making some rattle noise under load ONLY!!
got an '02 in the shop, runs great, but ONLY under load it has a rattling noise by driver side. It almost has the sound of bad valve adjustment, or sticking lifter. This only happens when driving the truck, not reving it up in park or neutral?? Any help??
oh ya it has 350K+ on it, used for towing dump trailer.
Old Nov 26, 2010 | 01:30 PM
Torque Monster's Avatar
I have the exact same thing
Any luck
Bump
Old Nov 26, 2010 | 01:42 PM
BriteWhiteRam's Avatar
sounds like you have injector rattle, maybe have a bad injector.... i would get the balance rates checked out
Old Nov 26, 2010 | 04:03 PM
I replaced mine 3k ago
I'm thinking mine is failed thermostat
Old Nov 28, 2010 | 03:51 PM
2500HeavyDuty's Avatar
the valves can go out of adjustment. its best to get t adjusted when you get your injectors changed.
when i got to mine they were over 3 times the oem clearence
Old Dec 6, 2010 | 03:46 PM
Mine happened to be a burnt ECT sensor
boostkid
Jun 3, 2015 11:17 AM
Max713
Apr 17, 2015 05:41 PM
Boatman
Mar 20, 2015 10:00 AM
cuda_cowboy
Feb 23, 2015 02:15 PM
dutchsupreme
Dec 18, 2014 01:44 PM
