06 F150 cummins 4bt conevert
Old Nov 5, 2010 | 12:42 AM
06supercrew's Avatar
Default 06 F150 cummins 4bt conevert
I want to take out my 4.6 gas and replace with a cummins 4bt will the trans bolt up? is there a conversion bell? or what tans can i use? also will the engine mounts line up? please let me know what i have to do to make the coversion. I have the engine already what else do i need to complete the install/ conversion.
my truck is a 06 f150 supercrew.
Old Nov 5, 2010 | 01:17 AM
stinkfist5.9's Avatar
what trans? i would say you will have to build your own mounts
Old Nov 5, 2010 | 01:19 AM
bobcat67's Avatar
alot of time and money and probably some pretty good fabrication skills, not sure if advanced adapters has anything for such a conversion, but i'm gonna answer no to the trans bolting up and to the motor mounts lining up
Old Nov 5, 2010 | 01:24 AM
I can build my my own mounts no prob just wondering what trans I should use
Old Nov 5, 2010 | 01:25 AM
bobcat67's Avatar
don't know much about the output of the 4bt, i'm assuming it's going to have a lot more torque than the 4.6, what i'm getting at is probably going to need to beef up the trans alot
Old Nov 5, 2010 | 01:27 AM
This is true, I think a turbo 400 chevy trans will work
Old Nov 5, 2010 | 02:11 AM
i think you need to check what engine adapter you have bolted to the rear of your engine first. what trans was bolted to your 4bt?
Old Nov 5, 2010 | 06:21 AM
the_new_kid's Avatar
The trans even though it is the (same) as what you would see on the diesels it is not there are slight HUGH differences. I would install a tranny from a 7.3 powerstroke and it should bolt up to the transfercase and hold up to the power. There are adapter plates (although espensive) from destroked and possibly ford cummins. I am working on a swap myself into an 04 f-150 (same body style)
What 4bt are you looking at using? P-pump, VE, or ISB?
Old Nov 5, 2010 | 07:57 AM
mikmaze's Avatar
I have seen some pretty stout power come out of one of those little four bangers. watched one dyno with 500 to the wheels, 125 hp per cylinder, running on wmo and a bit of diesel to thin it. The motor was in a 1500 chevy, and had a set of twins on it.
Old Nov 9, 2010 | 10:17 AM
Horns's Avatar
I wouldn't go with the th400 because it lacks an overdrive. If you have the cash to spend you could go with a 4l80e and get a stand alone contrller. Putting an NV4500 in her might make it a pretty sweet truck also.
