91.5 5.9 cummins wont start
Old Oct 31, 2010 | 03:55 PM
dtrapperfain's Avatar
Default 91.5 5.9 cummins wont start
did engine swap into a chevy, and engine does not fire. have fuel to injectors. engine will fire if given a small shot of starting fluid and with lines cracked at injector fuel pressure does squirt more. possible bad injector or injection pump weak ?
Old Oct 31, 2010 | 04:04 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
keep trying to bleed injectors.
Old Oct 31, 2010 | 04:19 PM
hane been for 2 day have turned engine over so many time i have 20 psi oil pressure while cranking
Old Nov 1, 2010 | 05:49 PM
fixed problem found cold engine temp sensor bad that runs from fuel s/d to temp sensor back to selenoid that increases fuel during cold starts
ronstop
Feb 26, 2015 09:48 AM
mcclusk
Feb 21, 2015 09:50 PM
trab123
Feb 9, 2015 09:44 AM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
