Check those FASS electrical connections!
Old Oct 29, 2010 | 09:19 PM
steved's Avatar
Default Check those FASS electrical connections!
Well, my FASS quit working in Washington. This is the second time I have had the FASS quit working during owning it. It had been working fine until today (as far as I remember hearing over the past couple days). The only good thing is this is a newer version that has a bypass in the pump which allows the truck to continue running (CP3 really doesn't need a lift pump).
First time was corroded terminals on the relay...pushing a new relay in and greasing those terminals solved that issue.
This time, I assumed maybe the relay failed...replaced the relay, no change. So I went further upstream, to the fuse. Found the fuse completely melted in the holder (but the holder wasn't damaged)...the culprit was corroded terminals that caused a batch of heat. Replaced the fuse and back in business at 20psi. The interesting part was the fuse holder appeared to be a weather-tight version...
Make sure you check both these trouble spots if you live anywhere you drive in a corrosive environment (salt water or winter salt)...don't get me wrong, I have over 180k on my FASS of cross-country driving, and it has performed well short these two hiccups.
JoeyMiR
9
Feb 3, 2018 10:05 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
CL-14
Oct 10, 2014 01:37 PM
