What to look for in 1997 f250
Hello.
I am not new to diesel but haven’t been around one since the early chev 6.2
any way I am looking at new to me Diesel right now I have my eye on 1997 ford f-250
Crew cab 2 wheel drive with 75,000 miles one owner truck. Is there any problems I should be aware of or look for. I am planning on using the truck to tow a 30 foot camper
Thanks
Thanks
Check for oil leaking from the following places.
The oil pan/ common to rust through.
Check in the engine valley/ the back of the high pressure oil pump is common to start leaking.
Exhaust back pressure actuator/ located in the turbo pedistal the actuator is a coomon palce for oil to leak out.
Than if you could I would have it scanned for codes. The truck could have issues with codes stored but no check engine light.
1st gen powerstroke f250's (94 1/2 - 97) came with an I beam front axle which can wear tires like crazy if its in need of ball joints, so look for a 350. if it has a 5th wheel or gooseneck hitch, powertrain is probly well worn.
1ATony
1A Auto Parts
Nov 23, 2015 11:39 AM
1ATony
1A Auto Parts
Oct 29, 2015 02:11 PM
1ATony
1A Auto Parts
Oct 15, 2015 10:58 AM
Sculpturesylvan
Oct 18, 2014 10:19 PM
