ticking
Old Oct 16, 2010 | 08:54 AM
wantpower's Avatar
Default ticking
when i start the truck i have a ticking sound from the engine, when you put your hand on the lines that run from the pump to the valve pan you can feel it, i know when you drive the rpms raise but the power dont. i pulled the plug on top the pump and try to fill it but cant get it completely full it bubbles and the level drops i quit after a quart its a 2000 7.3
Old Oct 17, 2010 | 06:36 PM
CSIPSD's Avatar
What pump? The HPOP?
You cant fill the HPO res to the top, it drains to the pan, it should be about 1/4-3/8" down from the top...
Old Oct 18, 2010 | 08:39 PM
wantpower's Avatar
yeah the hpop ok that is where it is thank you for the info still learning about these trucks could that ticking be an injector i had it hooked up and they all was hitting
Old Oct 19, 2010 | 11:09 AM
Lange503's Avatar
could be injector or exhaust leak? check your manifold gaskets, i've been having issues with mine lately
Old Oct 21, 2010 | 08:30 PM
wantpower's Avatar
ok thanks ill check them out
Hmfman91
8
Jul 3, 2015 05:52 PM
btg2820
Apr 27, 2015 12:09 AM
countryboy040993
8
Nov 11, 2014 07:40 AM
