lb7
Old Oct 13, 2010 | 06:14 PM
farfrommuvin's Avatar
Default lb7
i have a 2002 duramax with 225k and would like to know what i can safely do to get a little more performance out of it without messing up anything?
Old Oct 15, 2010 | 12:10 PM
Turbo Performance's Avatar
Intake, Exhaust, Programmer. I would stay on the lower levels of a program if the truck is completely stock. With that many miles the trans won't like big power.
Old Oct 16, 2010 | 02:09 PM
micgarcia's Avatar
my lb7 is gettin 24 on the highway with a 4 in turbo back and flash paq set on mileage xs..thats with 33 in tires and a level kit..
Old Oct 19, 2010 | 09:48 PM
WisconsinHick1's Avatar
Diesel Bombers Sponsor-Jags Diesel
You really don't need an aftermarket air intake the stock one with some swiss cheese holes in the bottom for more air is good up too about 500hp. Your best bet would be to upgrade programmers. It depends on money with what to go with. PPE is good or if you have the money EFIlive.
Old Oct 19, 2010 | 10:33 PM
DuramaxDiesel02's Avatar
Default Re: lb7
What's the stock pipe diameter?
Sent from my Rooted Droid as I'm driving 70MPH down the road
Old Nov 1, 2010 | 09:10 AM
CumminStrokeThisDuramax's Avatar
I have a 2001 Duramax with aprox. 260k miles on it and in my opinion it's just getting broken in. I run a Stealth 2 Race Edition programmer on it for the LB7 engine only and currently run it at 165 hp setting and it runs great. No sight of the tranny slipping although i have put it into limp mode one time within the 6 months that i've been running it on there. In my opinion you can do it if you want, it hasn't effected mine at all in any negative way. I will tell you tho if you do not like black smoke then i wouldn't turn it up past 90 hp or so because at 165 hp the smoke isn't real thick but it puffs out a pretty good cloud. Also you will see a significant improvement in speed, stock the LB7 will 0-60 in aprox. 10 secs, with the programmer it' roughly around 6 secs or so.
Have fun!
Old Nov 23, 2010 | 10:05 PM
Coopmax's Avatar
wouldn't go to big the tranny really doesnt like programmers with low miles much less with over 200,000 miles on it. I melted 2 trannys down before i learned. small efi live or ppe. look into suncoasts boost modifier valve for your tranny. helps hold pressure on the clutches only $85.
mlknutzen
Oct 1, 2015 10:56 AM
duramaxtuner
LB7 Performance
9
Aug 5, 2015 11:36 PM
dshopex4
14
Apr 15, 2015 09:40 PM
Adam Sanders
LB7 Performance
Jan 21, 2015 06:57 AM
Trevlar11
Dec 21, 2014 03:16 PM
