Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Best trailer battery kit?
Old Oct 8, 2010 | 01:29 PM
CreeperSleeper's Avatar
Default Best trailer battery kit?
I'm looking to put a winch on my trailer and will need some sort of battery to power it. It would be nice if the battery was charged from the truck towing it while plugged in but IDK if that is how it works or not... What are my options, oh sage trailer gurus!
Old Oct 8, 2010 | 04:16 PM
Deezel Stink3r's Avatar
It depends on what you want tow (weight) and how long you want to tow(time).Batteries will be killed very quickly if you don't recharge them as soon as you discharged them.
The second thing to have in mind is the extrem heavy current drain.
It will kill the battery if the battery is drained more than 50% which is about 12.2V. Most pople think when the lights dim the battery is empty- this is not true.It is already in a deep discharge state which will decrease your life span of the battery.
So you would need a heavy (or better called huge) deep cycle battery--->expensive!and of course some thick and expensive cables to recharge and connect the battery.
What about a HD come along? or those hand operated winches? Reliable, healthy (been looked at it from the sportsman side)and cheap?
But first you should know about your to-be-towed-weight...
Old Oct 8, 2010 | 04:35 PM
Captain Call's Avatar
My cousins trailer is set up with a winch. I believe he has 2 batteries (could be one) hooked to the winch and a constant charge off the 7-way plug off the truck when it's plugged in.
Old Oct 8, 2010 | 04:38 PM
It's a 3k lb winch that I have lying around. It would be used only if a rig is broke enough not to get on the trailer under it's own power. The length of the deck is just shy of 20' and the ramps are 5', so 30' max pull onto the trailer on a rare occasion...
Old Oct 8, 2010 | 04:48 PM
Might want to invest in a bigger winch. I wouldn't use that 3k on anything but an ATV or smaller.
Old Oct 8, 2010 | 04:51 PM
That sounds like the set-up I would want! Any more details you could give?
Old Oct 8, 2010 | 04:58 PM
I will look for a chart for rolling resistance and incline telling you exactly what kind of GVW of rigs you can pull with that winch. If you are willing to run the trucks engine while pulling and to invest the needed battery cable and connector I don't see any problems with using that winch. those hand operated winches to pull boats are much weaker and being used on passenger car trailers too.
Old Oct 8, 2010 | 05:05 PM
I don't, but I'm sure someone will have some insight. I believe you'd want one of these though http://www.atkinsonelectronics.com/p...s/TBCM-40A.pdf
Old Oct 9, 2010 | 11:06 AM
If need be, I have enough cable to run a ****** block on it. It will be more than enough for what I need and it will be free!
I like that! I would love to find that included in a full kit with a breakaway... (Not that I think my pintle set-up is going to come loose!)
Old Oct 9, 2010 | 02:44 PM
That relay will burn off.
Why?
1. Kirchhoff's knot rule applies: sum off current flowing in equals sum off flowing current out.
The winch will demand a lot of current and has two sources. battery and supply cable. If battery current diminishes all current possible to get will be sucked from the cable. The cable will resist and get hot- the next weak part is the relay. Expecting damage is guranteed if you don't disconnect the connection,
As I told you I looked for pulling weights
you have to divide towed vehicle weight by:
50 if you tow on road
10 if you tow on grass
5 if you tow on gravel
3 if you tow on sand
you also can calulate the inclination of the ramp with:
towed vehicle weight divided by 60 and multiplied by the inclination in degrees.
I hope this gives a general idea about the abilities of your winch(as you mentioned already you also can use a ****** block).
