need advice
I have a banks six gun programer on my 99 7.3 powerstroke. it dont make any smoke. can i put a ts chhip on the truck and not have to take the banks programmer off it. i want the truck to smoke a little but not all the time any advice?
Why would you want to keep the six gun on there?
You can't use a programmer on top of a chip. But the chip is going to give you a lot more power.
Kenny
Kenny
i want the programer because that tells me boost and egt. and i want to beable to make smoke when some little foregn rice burner pisses me off
. i know what smoke is i dont want to do it all the time.
I can set you up with a chip and set of factory matched gauges for a very reasonable cost. Then you would have everything your looking for.
Kenny
Kenny
depends on how strong your hpop is ... what year is your truck?
HPOP= High Pressure Oil Pump
These trucks have 2 oil pumps. The HPOP is used to open the fuel injectors. Typically, the higher horsepower tunes put the pump under more stress to keep the injectors flowing.
Thanks,
Kenny
Thanks,
Kenny
give kenny a call man he is did awesome with getting me my chip here in time and everything and awesome prices, and also speaking of gauges i would like to chang mine around a bit, hopefully be givin you a call durning lunch kenny
