Raptor lift pump wireing issue!
Old Oct 5, 2010 | 09:45 PM
R.Cassidy's Avatar
Default Raptor lift pump wireing issue!
The instructions say during installation to put the red wire into a spare fuse hole that is hot when the key is on, none of my spare fuse holes are hot! Spent two house trying to figure it out. Help please!
Old Oct 8, 2010 | 10:53 PM
the_new_kid's Avatar
You can actually go down to many auto parts stores and buy a add a fuse thinggy. (For lack of a better word) It allows you to keep the stock fuse at it's normal size and it has a wire coming off of it with a fuse to allow you to add another accessory.
Here is a link to what I am talking about Bussmann/ATM fuse tap converts one into two fusible circuits - 10 Amps maximum on added circuit (BP-HHH-RP) | Fuse and Accessories | AutoZone.com
Old Oct 9, 2010 | 10:43 PM
cummin_un_glued's Avatar
FormerVendor
the raptor wiring should have its own fuse allready...you could just t-tap it onto a wire somewhere else that is key'd hot insead of doing it in the fuse box...that's how i wired my CB in
Cavnar
Sep 9, 2015 07:18 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
veggyoilkid
Nov 10, 2014 12:39 PM
