97 powerstroke issue
Old Oct 5, 2010 | 08:34 PM
97 stroker's Avatar
Default 97 powerstroke issue
My 97 f250 started stalling the other day and cut off in the road and I started it bback and drove home well when I left my cousins who lives right next to me it did it again and wouldn't start and stay running. I switched the relay from the horn and the idm and it started but after I cut it off wouldn't start again. And the horn worked with the idm relay. The fuel pump dosnt make a noise when I turn the switch either. I bought a new fuel pump but decided I was gonna see what you guys thought before I got it dirty and couldn't return it
Old Oct 5, 2010 | 10:20 PM
PHPDiesel's Avatar
Sponsor
Do you have an electric fuel pump or Super Duty system? If not, then you won't hear the fuel pump run as it's mechanical and driven off of the camshaft.
The first thing I'd check is data. See what your injection pressure is doing. Check to see if you have an RPM signal to the PCM as well.
Old Oct 9, 2010 | 05:11 PM
IDMooseMan's Avatar
Another possibility is your CPS is failing. Have you had it replaced under the Ford recall?
Old Oct 10, 2010 | 11:59 AM
cummins bronco's Avatar
does your tach move when you are cranking?
if not it is probably the cps, they regularly crap out.
check your fuel filter housing, if it is full your fuel pump is probably fine.
Old Oct 10, 2010 | 08:53 PM
fordornothing's Avatar
i'd say cps. mine went out over night. it was fine one day then the next it wouldn't even try to fire....
Old Oct 11, 2010 | 07:41 AM
97 stroker's Avatar
It was the fuel pump like I suspected. Thanks guys
Diesel_Daddy6.0
Nov 12, 2015 09:33 PM
JKinni
13
Sep 5, 2015 11:09 PM
Lsugod85
Jun 20, 2015 05:14 PM
OBSBEN
Jan 8, 2015 08:21 AM
Oct 23, 2014 08:10 AM
