Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Diesel Kleen + Cetane Boost
Old Oct 3, 2010 | 08:49 AM
Highlander's Avatar
Default Diesel Kleen + Cetane Boost
So who all use this stuff..what's you opinion on it..I just tried it last week in my 98 Suburban and it seems to accelerate alot quicker and better fuel mileage, I was using 2 Cycle oil pryer too this. I'm just curious if I should keep running this additive, (just hope theirs nothing in it that would harm the Engine).. cause it definitely pulls harder that's fore sure..
Old Oct 3, 2010 | 10:12 AM
wildbill's Avatar
I never could get accurate results running the stuff. So I can't help ya much.
Old Oct 3, 2010 | 07:24 PM
promodcummins's Avatar
Alot of my buddies run that mixed with a quart of 2 stroke oi every other fillupl. I run the XDP diesel additive mixed with 2 stroke.
Old Oct 9, 2010 | 02:17 PM
gunman41mag's Avatar
Moderator
I did get better MPG from my 1999 7.3 F-250 using it
Old Oct 9, 2010 | 05:55 PM
44'snot24's's Avatar
i agree with gunman i did to
Old Oct 10, 2010 | 01:33 AM
moparcop's Avatar
I just put some in my 24v and haven driven it enough to get a mileage reading but throttle does seem a little more responsive now, shes got a little more get up and go.
Old Oct 16, 2010 | 02:23 PM
Mike H's Avatar
sorry to throw my own question in here,but are you guys saying that it is good for the engine to add 2 stroke oil?if so how much.
p.s. diesel kleen helped my brothers 7.3 alot in fuel mileage
Old Oct 16, 2010 | 02:34 PM
kingbrad89's Avatar
I run diesel kleen with cetane boost and slickdiesel in every tank all year round especially in winter as a stabilizer/anti-gel. The main reason I run it is for the slickdiesel lubricant to extend the life of the expensive hotrod injection pump... They're only lubricated by the fuel so every little bit helps! It's expensive tho... I run 16oz in each tank. So that's like 5 bucks worth per tank
