HELP! Was idling then just quit!!
Old Oct 3, 2010 | 08:38 AM
dragraceratx's Avatar
Default HELP! Was idling then just quit!!
2004 duramax....Cranks fine... was just sitting there running then it was like someone shut off the key. Im sure i can fix it if i can get some hints on where to start. not sure how to tell if its an LB7 or not. Thanks in advance!
I know im a newbie guys... gotta start somewhere!! Help a "brotha" out please......
Last edited by dragraceratx; Oct 3, 2010 at 08:38 AM. Reason: Automerged Doublepost
Old Oct 4, 2010 | 10:05 AM
bftrain's Avatar
Does it start back up fine? Is the priming pump hard to push after it stops? The vin tells you which motor the 8th digit 1=LB7 or 2=LLY.
Old Oct 4, 2010 | 10:56 AM
94cummins diesel's Avatar
its a lly an check ur injection pump
Old Oct 4, 2010 | 05:54 PM
bftrain's Avatar
Did he send you more info than I got? 04 is LB7 and 04.5 is LLY only way to tell is the 8th digit in the VIN.
Old Oct 4, 2010 | 06:07 PM
Red_Rattler's Avatar
High Tech Redneck
Def check the underhood fuse box for any blown ones. Can't remember what fuse we used for his kill switch for his emergency shutoff but with that fuse out the truck will only crank and not run.
Old Oct 4, 2010 | 08:55 PM
cstlb7's Avatar
my 2001 was having the same problems and i couldn't figure it out to save my life it turned out that my return lines were shot my fuel rail pressure was only at 1400 i believe it is supposed to be at 4000. but anyway it was the return and once i got that fixed it ran great. but was your truck going into limp mode before or were any dtcs showing up?
Old Oct 6, 2010 | 01:15 PM
It had lost its prime... kinda like me :-) pumped it a few times and lit right off... no problems since.
Old Oct 6, 2010 | 07:56 PM
blazier18's Avatar
ever heard of a dodge? you should look into one!!
Old Oct 6, 2010 | 08:02 PM
BLACKDX's Avatar
Is it still good? Seems kinda funny it did that must be a leak somewhere guess youll know if it does that again..
Old Oct 18, 2010 | 06:00 PM
I did the other day. 2006 with 130k. pulled the oil cap to check for blow by and it blew it out of my hand... POS no thanks!
no problems since
Last edited by dragraceratx; Oct 18, 2010 at 06:00 PM. Reason: Automerged Doublepost
98suburbandiesel6.5l
Jul 25, 2015 03:25 PM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
Sophia'sJustice
Mar 5, 2015 04:06 PM
stewart.william.c
Feb 11, 2015 01:39 AM
