STICKING THROTTLE(855 CUMMINS
Old Oct 1, 2010 | 07:14 PM
isletlake's Avatar
Default STICKING THROTTLE(855 CUMMINS
i HAVE 86 Kenworth with 315 hp cummins, all of a sudden my throttle is sticking. It is in the injector pump some where, not in the linkages.
Will not throttle down once you press on the throttle unless you slap the throttle pedal, started doing it this morning going to pick up load of gravel.
Can any one help me with this?????
Old Oct 1, 2010 | 07:25 PM
wildbill's Avatar
Sounds like the cable is getting corroded on the inside. Might be able to free it up with some heat and penetrating lube.
Old Oct 1, 2010 | 08:41 PM
cumminspwrram59's Avatar
you can try to spray some penetrating oil on the linkage on the pump. if not i would say take it to a shop and have them look at it. there are internal linkages on these pumps and if something happens it will either be all or nothing. stick wide open or not go at all
Old Oct 2, 2010 | 10:32 AM
cummin_un_glued's Avatar
FormerVendor
i dont know anything about those pump but couldnt it be a gov problem also?
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
Oct 20, 2014 08:10 AM
