Need help with rim offset for 02 dmax.
Old Sep 26, 2010 | 03:32 PM
02LB7DURAMAX's Avatar
Default Need help with rim offset for 02 dmax.
Hey guys I have an 02 dmax cc/sb summit white and I am going to put a 4" suspention lift on and run 35"12.50 toyo m/t's with 18" black rockstars, and I was wondering if anyone has any pics of something like I want to do. Also I need to know what offset I need. Thanks for the help.
Old Oct 1, 2010 | 09:36 AM
Can someone please help me thanks!
Old Oct 1, 2010 | 09:52 AM
94cummins diesel's Avatar
my buddy does ill snap a pic an post it here kk
Old Oct 4, 2010 | 07:31 PM
ShockerSteve's Avatar
you wount want a 4.5" backspace to have them stick out a bit.
Old Oct 5, 2010 | 01:28 PM
dmaxtothemax's Avatar
I just ordered some rims with a -12mm offset so they would be a deep dish instead of tucking the tires under the fenders... From what i understand (i might be wrong), your offset is the movement from the center of the wheel with the centerline being 0 (zero) and face (outside) of rim being + (positive)... thus the negative offset should be, in my case, 12mm back from centerline making the backspacing less which makes the rims look deeper... someone please correct me if im wrong...
Old Oct 18, 2010 | 06:45 PM
ok guys thanks for the help.
ChevyGuyForLife
Chevy/GMC Duramax 06-07 LBZ
Jan 13, 2015 12:29 PM
