Street And Track Racing Diesel Discussions of Street And Track Racing Practices , Techniques , Tips and Kill Stories PLEASE BE CIVIL
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
boosted launch
Old Sep 20, 2010 | 06:20 PM
450r's Avatar
Default boosted launch
so what is really considered a boosted launch.
what do most guys launch at?
i know that it takes a good bit of throttle to even make one or two psi.
so my question is i have a stock trans maybe addign a vb to it and i have current mods in sig runnign on 70 hp settign . planning on going to the drag strip for mason dixon diesel day oct 24 and was thinking about running once or twice to get a time . if i didnt really built any boost but built up soem rpms to take away from lag would i hurt anything anymore than jumping on it from idle ??
Old Sep 21, 2010 | 12:01 AM
TruePerformanceDiesel's Avatar
FormerVendor
I launch at 3-5psi sometimes 7 if the tires hold in 2wd. I have to mash the brakes to hold it back. But then again I have a 05 Dmax which is completely different. It can be hell on a stock TC. You should be fine to run a few passes.
oglejust's Avatar
most ppl launch at 10psi or so
Old Sep 21, 2010 | 06:50 AM
450r's Avatar
ok thanks more opinions guys
Old Sep 21, 2010 | 05:55 PM
BIG NIG's Avatar
i just did some boosted launch experiments........
15psi: kinda laggy, lit and all hell broke loose about 40' out and started painting the pavement
20psi: got about 3' then 4 gears and 200+ft of painted pavement
but i got a 2wd 12V fatt butt
Old Sep 25, 2010 | 08:55 PM
ztk7220's Avatar
what is the best way to do a boosted launch with a manual trans
Old Sep 27, 2010 | 11:44 AM
PLMCRZY's Avatar
Start in 3rd........
Old Sep 27, 2010 | 11:57 AM
Lostnwalmart's Avatar
With at least 20 lbs
Old Sep 27, 2010 | 01:15 PM
PLMCRZY's Avatar
And plenty of fuel to keep it spooled when you dump it
Old Sep 27, 2010 | 02:23 PM
BIG NIG's Avatar
line lock is the easiest but hold the accelerator to the floor with your heel and toes on the brake and start easing the clutch out till your desired boost then sidestep the clutch and firmly plant your foot all the way on the accelerator...........something should happen good or bad
