GM diesel tech needs help
Old Sep 20, 2010 | 12:11 PM
sprintracer27's Avatar
Default GM diesel tech needs help
I have a '99 powerstoke, starts, lacks power, heavy smoke white (fuel) and knocks. Check compression on all cylinders, 400-500psi on all cyl. Noticed when doing compression test, it appaered to have fuel spray from glow plug holes. I am assuming that it needs injectors. Has dtc p1212 stored, Check oil level in oil pump resvoir was full. When I ran the engine and monitered data on scan tool, oil pressure seemed to match actual to desired. Not quite sure where to go from here. Any help is appreciated.
Old Sep 20, 2010 | 08:17 PM
wildbill's Avatar
Sounds like bad injectors.
Old Sep 20, 2010 | 08:56 PM
PHPDiesel's Avatar
Sponsor
Fuel spray from glow plug holes equals bad injectors or injectors that have become unseated (loose hold down bolts).
Jet A Fuel
Aug 3, 2015 10:45 AM
Mar 20, 2015 08:20 AM
Jan 13, 2015 09:00 PM
Nov 28, 2014 09:50 PM
Oct 13, 2014 08:10 AM
