Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
battery replacement gone bad
Old Sep 19, 2010 | 10:52 PM
SmokiinRam's Avatar
Default battery replacement gone bad
so i bought a new 1st gen cummins yesterday and it has a high dollar sound system all top of the line.and it sounded good earlier when i played it,but i was working on the carpet with the door open for a while and the dome light drained the battery and when i turned the stereo on it sounded crappy and all static even on cd,so i thought there wasnt enough to supply the amp and the battery meter said it was drained.so i was changing the old battery for an optima and when i was tightening the cables my wrench shorted the terminals and now i have no radio..but wierd thing is is that the dome light and everything else works so i dont know what happened?? any help appreciated...sorry this is so long
Old Sep 20, 2010 | 01:55 AM
Scoprius's Avatar
Check your fuse panel and if its not in the panel the inline fuse on the decks wiring harness usually one or the other is blow when you short the battery terminals.
Old Sep 20, 2010 | 03:42 AM
Deezel Stink3r's Avatar
Yes, it does sound like a blown fuse. Don't worry.
If you listen very carefully, you might also hear a difference in sound. Bass will be reproduced tighter and treble sounds way crisper. This positive effect is caused by the very low internal resistance of the optima. The optima is able to deliver the current the amp needs.
Good choice!
Old Sep 20, 2010 | 10:03 AM
SmokiinRam's Avatar
thanks guys really relieved some stress from this i thought i melted something, ill have to check it when i get off work.yeah i have always used optimas theyre great batteries
Old Sep 20, 2010 | 03:37 PM
motorboat's Avatar
If you have an external amp, that is the fuse or link that got toasted.
Old Sep 20, 2010 | 04:17 PM
SmokiinRam's Avatar
i do have an external amp too
Old Sep 20, 2010 | 04:47 PM
gixxertricks's Avatar
definitely a fuse
Old Sep 21, 2010 | 09:22 AM
SmokiinRam's Avatar
i fixed it yesterday there was a 10 amp fuse in the back of the player was a pain to get to but did it.the amps fuses were fine thanks guys
Old Sep 21, 2010 | 10:35 AM
Thank you for your feedback!
Flash123
Ford Powerstroke 08-10 6.4L
Jun 25, 2015 10:19 PM
misstiffany
Mar 21, 2015 09:43 AM
carid
Diesel Bombers Sponsors
Dec 4, 2014 05:06 AM
Kentonjl
Sep 30, 2014 07:22 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
