need some advice.. injectors what kind do i need?
Old Sep 13, 2010 | 04:03 PM
TN12valve's Avatar
Default need some advice.. injectors what kind do i need?
alright everyone im doing a senior project and i wanted to do something i could get a credit for and enjoy long after im out of school. im very intrested in learning more about mechanics im not just here to see smoke like most kids are. so far ive got #100 plate, intake, exhaust, starwheel, and clamped wastegate. only downfall is this truck has 220000 on it and original tranny. im going to be hauling a pretty good size boat this next year and was wondering if i should get injectors?? if so what kind?? i dont want to break the bank either. its either injectors or gauges i know i should already have the gauges but dont which do yall think i need most?? or should i just start saving my money for a built tranny???
Old Sep 13, 2010 | 04:08 PM
12vcummins96's Avatar
guages then tranny then injectors imo
Old Sep 13, 2010 | 04:23 PM
TN12valve's Avatar
thanks but with the gauges n built tranny how many hp sticks should i get? what about marine injectors are they worth it or should i save n get some name brand stuff
Old Sep 13, 2010 | 04:50 PM
Red_Rattler's Avatar
High Tech Redneck
If you add sticks to the mix you have going on now you'll def kill the tranny towing the boat. Also marine injectors are not the way to go, all they give you is hot dirty somewhat cheap power. A set of 5x.014 from Southern Diesel Extreme (sponsor on the site) makes very nice correct spray pattern for the 12v at a very reasonable price. But I agree gauges tranny then sticks. Make it reliable first then add the power.
Old Sep 14, 2010 | 03:39 AM
blazier18's Avatar
96cummins is right. imo its better to buy once then keep replacin stuff and buildin a tranny can be as much as u want the liffle mods u have done and with injectors a double disc torque converter will do that and injectors. but get ur gauges before u put sticks in. dont get no marine 370's they have a 155 spray angle ur lookin for a 145. i just bought a new set today extrude honed 150's i haul everyday. stock tranny im buildin a standard though. but 90 hp should be enough for u but private message me or text 865 659 0466 ill explain a little more
Old Sep 14, 2010 | 08:55 AM
94 12valve's Avatar
is your senior project your truck? where are you located? someone may be close to help
Old Sep 14, 2010 | 01:24 PM
sstockton's Avatar
I would run Gauges, the trans, and a set of 215hp injectors. With the right pump tuning, it is no problem to max out your stock charger with a set of 215hp sticks. From there I would start looking at what you really want to get out of the truck, power and purpose wise, and come up with a plan from there, and start by addressing the supporting mods first. Studs, O-rings, what components your trans needs etc... Then what you will need as far as air and fuel and tuning to get your truck where you want it.
Sean
Old Sep 14, 2010 | 09:59 PM
TN12valve's Avatar
thanks everybody i appreciate it, today i went to check some gauges out ive got a friend at napa he said tranny temp, pyro, boost with the pilar mount is 400 bills. is that high? oh and to 94 12 valve i live south of nashville franklin-spring hill area the only performance shop around is DBR i need to get an est. on gauges there aswell. but thanks everybody for your imput!! im sure ill have many more ?s to come.
oh and yes its my truck i plan to keep it forever. my dad bought it brand new back in 96 he was one of the most well thought of mechanics around. he kept this truck completly stock we pulled a 5th wheel for a good while with it and boat. he passed back in Feb. so in his memory i plan to fix it up and keep it forever i have a note pad he kept of every oil change and maintnence he ever did to it since 96 and i know how he took care of it and i plan to do the same. once i settle down n get a steady job it will become a weekend ride to keep some miles off it until i can buy another cummins!! haha
Old Sep 15, 2010 | 12:16 PM
94 12valve's Avatar
Thats awesome sorry to hear about your dad tho
Old Sep 15, 2010 | 03:59 PM
BAD ASS RAM's Avatar
Ill help all I can as we live only an hour and a half from each other
