Dash not straight after heater core replacement
Old Sep 12, 2010 | 09:33 AM
Marine's Avatar
Default Dash not straight after heater core replacement
Replaced my heater core yesterday. Have it all back together but 1 problem; the driver side end of dash is sitting about 1/4" high and 1/4" forward than what it should be. Passenger side is fine. Does anyone know what could be holding it up? I can't find anything. It does not budge at all.
Thanks!
Old Sep 12, 2010 | 11:29 AM
wildbill's Avatar
Didn't bend/break any of the plastic tabs??
Marine's Avatar
There aren't really any plastic tabs....
Old Sep 12, 2010 | 11:34 AM
wildbill's Avatar
IDK, but you may have to tear it back apart.
Old Sep 12, 2010 | 11:38 AM
Marine's Avatar
I will have to; just want to find some ideas on what to look for when I do it.
Thanks!
Old Sep 12, 2010 | 11:43 AM
tiremann9669's Avatar
If it's like a 96 there's a bolt at each end that the dash sits on and pivots up into location. Is it sitting all the way down on that bolt ?
Old Sep 12, 2010 | 11:59 AM
RAW's Avatar
RAW
I agree with that. The pivot bolts on the outside, bottom of the dash frame are probably the problem.
Old Sep 12, 2010 | 12:11 PM
Marine's Avatar
I can tell the Driver Side is sitting just under 1/4" high and towards the seat according to the pivot bolt; Need to figure out why though.
It is not sitting in the same spot as it used to.
Old Sep 12, 2010 | 01:00 PM
Get that wrench out from under it
Old Sep 12, 2010 | 03:30 PM
Marine's Avatar
Haha good one!
I didn't even have any parts left over from this job!
