turbo time
Old Sep 10, 2010 | 08:36 AM
96blackcloud's Avatar
Default turbo time
what would be a good turbo upgrade for my application. i want a fast spooling turbo. i have heard that there is a turbo off equipment i can use a s3xx something and i have heavy equipment at my disposal.
Old Sep 11, 2010 | 02:39 AM
Turbo Performance's Avatar
Most heavy equipment/semi turbo's are going to have too large of an exhaust housing to just bolt on your truck and spool anything even close to fast. They won't be a T3 flange either, so if you did find one that would work you would need an adapter.
If I were you, I would be calling turbo companies and asking them what they recommend for how you use the truck and what your goals are. Probably the easiest/fastest way.
Old Sep 11, 2010 | 12:58 PM
big willy's Avatar
you may have got the injectors first. but i got a turbo
Old Sep 12, 2010 | 12:05 PM
monster12valve's Avatar
i like the super b special. thats what i am going to run here shortly.
Old Sep 12, 2010 | 12:13 PM
wes-cummins's Avatar
i think the s-300 has a t3, if you found a piece of heavy equipment with a 350- 500 inch motor it might be worth a try to swap turbos and see what it does
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
sak240
Oct 1, 2015 04:07 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
