Exhaust Manifold Porting
Old Sep 9, 2010 | 11:30 PM
rkadcock's Avatar
N.M. Bombers Director
Default Exhaust Manifold Porting
While I have my Super B Special pulled for some warranty work, I was kicking around the idea of getting my exhaust manifold ported. Sounds easy, but is that really the case? I figured I'd line up the gaskets mark where I want to port, then take a dye grinder to it... Is their anything special to be known before I take the grinder to it?
Old Sep 10, 2010 | 09:43 AM
94 12valve's Avatar
make sure its smooth when you done, and make sure there is some meat left when your done
Old Sep 10, 2010 | 02:44 PM
cumminspwr11's Avatar
i was thinking about doing this as well, i saw a thread some where else that had a really good write up and all the people that had done it said their egts drop 100-200* and the spool up time improved, some of them also took some meat out of the head and on the turbo flange as well
Old Sep 10, 2010 | 09:21 PM
rkadcock's Avatar
I'll let you guys know how it goes tomorrow... I'm going to take away from the inlets and some off the turbo flange. I really want to port the exhaust side of my head but I don't plan on pulling the head again for awhile...
Old Sep 11, 2010 | 11:12 PM
a suggestion that i heard for porting the head was to make sure the cylinder you are porting is a tdc and stuff a rag or something in there and blow it out really good after your done
Old Sep 12, 2010 | 12:09 PM
wes-cummins's Avatar
make sure its tdc compression/powerstroke so the valves are closed,
i ported the manifold on my brothers vp truck and now she spools up really fast and droped temps a bit, i didnt gasket match thos just smoothed the inside and took down some sharp corners, started with a carbide bur and fisished with 200 grit cartridge rools
Last edited by wes-cummins; Sep 12, 2010 at 12:09 PM. Reason: Automerged Doublepost
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
