4 wheel drive trouble.
Old Sep 6, 2010 | 09:11 PM
svt28640's Avatar
Default 4 wheel drive trouble.
My 4 wheel drive has quit workin. Turn the switch an nothin at all with hubs in locked or unlocked. Any ideas
Old Sep 6, 2010 | 09:17 PM
7.3 Cowboy's Avatar
CAn u hear the elcetric motor move?
Old Sep 6, 2010 | 09:28 PM
svt28640's Avatar
no i dont think so
Old Sep 6, 2010 | 09:53 PM
7.3 Cowboy's Avatar
its either the motor is bad or a bad connetion
Old Sep 6, 2010 | 10:31 PM
svt28640's Avatar
that cause dash light an everything not to work?
Old Sep 6, 2010 | 10:47 PM
ju015dd's Avatar
When you turn the 4x4 on with ac on does it start to come out the defrost vesnts? You either have a going bad vacuum pump or more than likely a leak somewhere on the vacuum lines.
Old Sep 7, 2010 | 12:40 PM
CSIPSD's Avatar
Check your fuses. Then crawl under the truck and unplug the switch at the T-case and fill the connection with Dielectric grease, plug it back in and try again.
Sounds like a blown fuse... Vacumn leak would NOT keep the T-case from engaging, just keep the 4x4 from locking up.
Old Sep 23, 2010 | 02:11 AM
svt28640's Avatar
I checked my connection, an only found one fuse for the 4 wheel drive and it was good. Am i missing a fuse or does anyone have any other suggestions? Thanks
Old Oct 18, 2010 | 07:55 PM
svt28640's Avatar
bump
Old Oct 19, 2010 | 04:45 PM
CSIPSD's Avatar
Did you do any trouble shooting at the connection? Is your vacuum pump working?
