6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
whats next?
Old Sep 2, 2010 | 09:50 AM
strokethis's Avatar
Default whats next?
i have a 2006 f-250 with AFE straight 4in ,S&B coldair intake and SCT X3 with custom tunes from eric. what is next other than headstuds and egr delete. i have 60,000 miles on the truck still under warrenty.
Old Sep 2, 2010 | 01:32 PM
Mdub707's Avatar
Next IS headstuds and EGR delete!
A coolant filter is a good idea, what about gauges? You don't have gauges yet? That would be a pretty important mod to have on there! Also a direct shift solenoid is a good cheap investment. You can get it from suncoast, or Doug @ GoGo can custom make them (I'd get the GoGo one personally).
Old Sep 2, 2010 | 07:05 PM
HeavyAssault's Avatar
Fuel sump and an AirDog....
Old Sep 3, 2010 | 09:47 AM
strokethis's Avatar
i got pyro ,boost ,tranny ,fuel pressure ,oil temp guages. what does the solenoid do?
Old Sep 3, 2010 | 10:19 AM
Farmboy 2.0's Avatar
Do headtuds an egr delete a lift pump. Then you can get into the high performance HPOPs and injectors. And if I remember right you can buy an 03 vgt turbo and pedestal and thats considered a stage 1 turbo upgrade for 6 liters
Old Sep 3, 2010 | 04:33 PM
Mdub707's Avatar
You can buy an 03 turbo and mount it on the pedestal you have, but you can only use 2 bolts, FYI. Saves you the trouble of having to purchase a pedestal. Stage 1's are usually around a 62mm if I remember right, and stock is what a 57ish?
The solenoid can be read about here: http://store.gogodiesel.com/index.ph...29omim03epp0f5
Again, a coolant filter is a really good idea. The blocks on the 6.0 are sand cast from the factory and over time those sand particles break loose and cycle through the coolant system, eventually clogging your oil cooler, which is what leads to things like blown EGR coolers and failed headgaskets. It's not expensive either at $119 or so.
To add to that, since you already have an oil temp gauge, and water temp gauge will be nice because you can monitor the difference's in temps. Your oil and coolant should never exceed 15 degrees apart. If it does, it's the early warning signs of a clogged oil cooler and leads to the issues I just mentioned above.
IMO, an aftermarket HPOP is a waste of money, UNLESS your stock one has failed, then it just makes sense because they're less than an OEM one. Shawn Ellertons 1000+hp 6.0 is running a stock 05 HPOP. (or was up until very recently).
Old Sep 6, 2010 | 10:55 AM
yeehaw's Avatar
gogo still doesn't have info up on the solenoid?
Old Sep 6, 2010 | 02:44 PM
Mdub707's Avatar
Yes, there is a very good description of it on there. I think I messed the link up. Try this...
TorqShift Transmission Upgrades : Direct Injection Performance - GoGoDiesel.Com, Your Source For All Things Diesel!
If that doesn't work, just go to their main page, Direct Injection Performance - GoGoDiesel.Com, Your Source For All Things Diesel! and then click on 6.0 powerstroke, then torqshift transmission, then click on the solenoid and you can read all about it.
*EDIT* I just clicked all through it again myself and you're right the info isn't there now. It was there when I posted the first link!? I guess I'd just call Doug and see what he says. Wish I had saved the info now....
Old Sep 6, 2010 | 09:21 PM
yeehaw's Avatar
yea i am super curious about it
