Losing High end power-any thoughts?
Old Aug 31, 2010 | 03:12 PM
camperhauler's Avatar
Default Losing High end power-any thoughts?
When running in 5th and 6th gears I lose a lot of power-usually 45mph is top end speed at times? Have all the power needed in low end gears but nothing in high end. Any thoughts or ideas would be helpful.
Old Aug 31, 2010 | 09:15 PM
white93's Avatar
I would start cheap and change the fuel filter first. If its the '96 you have listed at the top then it could also be the overflow valve.
Old Aug 31, 2010 | 10:29 PM
I am on the third fuel filter in as many weeks. I have also changed the outer air filter, havent found a parts store that carries the inner one yet.
I recently added another fuel tank to the passengers side of the truck, it is only gravity fed to the main fuel tank. Could this be an issue?
robbyS
Apr 16, 2015 02:22 PM
countryboy040993
Mar 21, 2015 04:47 PM
