smog test
Old Aug 29, 2010 | 09:26 PM
droth26790's Avatar
Default smog test
does anybody know anything about the smog testing in Calif. I took the muffler off and running a stright pipe. I also have a S&B air intake.
do you think I will have any problems passing the test????
Old Aug 29, 2010 | 09:39 PM
Rustin's Avatar
Check this link it will give you all the info needed for you.
Diesel Vehicle Smog Check Inspections Information
Here is one from the same site that has a video of the inspection.
This one is on the Executive Order Parts Pending This link only tells you what is being looked at it does not tell you if they are leagal to use.http://www.arb.ca.gov/msprog/aftermk...gress_list.pdf
this is a lengthy PDF on Aftermarket parts. Aftermarket, Performance and Add-On Parts
This one is important to look at!
http://www.autorepair.ca.gov/80_BARR...24_2009_gc.pdf
I hope this helps!
Thanks for the thread
Rustin
Old Aug 29, 2010 | 09:52 PM
tiremann9669's Avatar
Straight pipe and air intake just lets it breathe better, I don't see how that could affect a smog test untill you start adding fuel.
Old Aug 30, 2010 | 01:31 AM
Rustin's Avatar
If thats all you are doing is straight piping a non Catalitic exhaust system? You might be OK. However; Ignorance of the laws is of no excuse. So make sure for your self!
Old Oct 27, 2010 | 01:26 AM
1longbed's Avatar
I just did mine and the Tech told me they just check for smoke and programmers on the intake for a C.A.R.B number. They have a list of parts that are ok and not ok, I would ask about the intake first befor you test it. Ohh and I passed with Banks turbo back 4" intake elbow but had to disconnet the programmer.
Old May 1, 2013 | 08:13 PM
HJOHNSON61697's Avatar
Has anyone passed the smog test with a straight pipe my truck doesn't have a Cat and I am trying to figure out if I can straight pipe my F-250 and still pass smog. Thanks.
I live in San Diego so does that mean even though I don't have Cat I still have to get smogged?
Last edited by HJOHNSON61697; May 1, 2013 at 08:13 PM. Reason: Automerged Doublepost
Old May 1, 2013 | 10:52 PM
Bigg Redd's Avatar
You will definately need to have the cat in place for the visual inspection and smogging. If the cat isnt there, they wont go any further with the testing......... aka FAIL.
Old May 2, 2013 | 12:49 AM
2004LB7's Avatar
Nitrous oxide will go up with a leaner burn
Old May 2, 2013 | 05:07 AM
97cummins's Avatar
biggredd is right, your in california, if you don't have your muffler and/or cat, automatic fail.
Old May 2, 2013 | 08:19 AM
I've passed smog before without a cat because my truck came stock without one.
