truck pops above 2500
Old Aug 27, 2010 | 11:22 PM
BAD ASS RAM's Avatar
Default truck pops above 2500
i have recently had the timing bumped up and he set it a couple different ways,it ended up being around 22 degrees.i also shimmed the gov. springs and now it sounds like it's popping above 2500 rpm's what is going on here??it is pulling good.
Old Aug 27, 2010 | 11:37 PM
biged681985's Avatar
it sounds like it could be a timing issue, are u sure u got it at 22*? maybe the pump slipped in the gear?
Old Aug 27, 2010 | 11:42 PM
i don't know,would it be advanced too far?he had to use the spillport method.we couldn't find the specs on the pump it says 847 i can't find anything on it
Old Aug 30, 2010 | 10:24 AM
BRE's Avatar
BRE
It might possibly be running out of fuel too.
Old Aug 30, 2010 | 11:51 AM
94 12valve's Avatar
your sure it's at 22*?
Old Aug 30, 2010 | 02:26 PM
sounds like my truck when it was at 11* it would pop bad above 2k
Old Aug 30, 2010 | 02:28 PM
BIG NIG's Avatar
it "pops" free reving it or under load?
Old Aug 31, 2010 | 09:38 AM
i think just under a load and he said he's sure it's between 22 -25 degrees and its not really a pop as much as a cracking sound or something it's hard to explain i guess it sounds similar to a jake brake????
Old Aug 31, 2010 | 10:26 AM
Farmboy 2.0's Avatar
That is alot of timing for just driving on the street IMO.
Old Aug 31, 2010 | 12:00 PM
oglejust's Avatar
That's too much to vary... check the timing again could be air in fuel also
