alt, and tach problem on 01 with 12 valve
Old Aug 27, 2010 | 01:47 PM
patrickdavina2's Avatar
Default alt, and tach problem on 01 with 12 valve
I'm new here and am in dire need of help. What I have is an 01 3/4 ton that had a 24 valve with a blown motor. I've pulled the 24 out and replaced with a 12 valve, here lies my issues......1 tach doesn't work, 2 alt. Doesn't charge. Any help would be greatly appreciated
Old Aug 27, 2010 | 04:06 PM
mishkaya's Avatar
Did you replace the PCM with a '98 12V model? If not, you will have this type of issue. As I recall the 12V engines read the engine RPM from the crank speed sensor on the front balancer, and the PCM controls the alternator; whereas the 24V engine reads the engine from the cam position sensor. I know you can wire in an external voltage regulator to bypass the PCM controlling the alt, but I am not sure on what you need to do to fix the tach issue.
Hopefully someone with experience with this type of issue will chime in. I have never done a 12V swap yet, although one will be in my future at some point in time...
Good luck.
Old Aug 27, 2010 | 04:37 PM
24 valve does use a cam sensor and the 12 uses a crank what I did was get a kit. From destroked that bolts on the balancer that has a two wire sensor my problem is hooking this sensor to the existing wiring
Old Aug 27, 2010 | 05:07 PM
mishkaya's Avatar
Maybe if you ask in the conversions forum, someone else who has done the conversion can give you some pointers. you will probably get better exposure there:
Diesel Engine Conversions - Diesel Bombers
I wish I could be of more help...
Old Aug 27, 2010 | 05:54 PM
Well thanks just the same do appreciate any help or advice
Old Aug 27, 2010 | 10:23 PM
biged681985's Avatar
u need an adapter for the cam sensor like they use for p-pumping the 24v trucks
Old Aug 28, 2010 | 02:34 PM
Got one from destroked with a 2 wire. sensor tach will pickup for about 20 seconds then goes to nothing I'm beginning to be at a complete loss here
