Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Intercooler Leak Detection...
Old Oct 19, 2007 | 02:09 PM
mojo_jumper's Avatar
Default Intercooler Leak Detection...
i am sure i have a small leak somewhere in the charge air system...but i cant damn well find it. has anybody here used those rubber caps with the air hose fitting that goes on the inlet side of the turbo?? what other methods have you used to locate small leaks?? Thanks.
Old Oct 19, 2007 | 02:20 PM
Johnny Cetane's Avatar
cap a chunk of PVC pipe and then thread to take an air fitting. you can put a regulator on it too or on your compressor. set it to about 15-20 psi.
BTW, welcome to Diesel Bombers.
Old Oct 19, 2007 | 02:26 PM
Whit's Avatar
Site Mascot
test yer air charge system you may have a leak
easy to do just go get ya a 4" rubber boot and a 4" PVC 40 schd cap....tap the cap to accept some 1/4" plumbing to include a gauge and a tire valve nipple ..............get a couple good clamps and clap the thing on yer turbo inlet and charge it up with yer air compressor.
I did this to 11 trucks during a truck rally at my shop and guess what......found leaks on every single truck including mine
Old Oct 19, 2007 | 02:32 PM
DangerousDuramax's Avatar
You can always inject a small amount of marvel mystery oil on the intake side of the turbo.
Old Oct 19, 2007 | 02:33 PM
Originally Posted by Whitmore
including mine
That dont surprise me.
Old Oct 19, 2007 | 02:45 PM
say what???
Old Oct 19, 2007 | 02:49 PM
Marvel mystery oil white smokes like crazy when burned. It's the best thing to run through and engine to blow it out and for long term storage. If you shoot a little on the intake side of the turbo you will see the smoke come out where the leak is.
Old Nov 6, 2007 | 08:44 PM
dalton06's Avatar
when you pressure test the system does it hurt the truck to have so much air pressure on it without running? How high should I run it up to? I want atleast 40psi back. But my turbo is set to open at 50psi?
Old Nov 6, 2007 | 08:53 PM
bow2no1's Avatar
test it from the exit side of the turbo also just take the hose off.
you should just build up pressure and hear or use soap and water to see where it's leaking from..
it's probably not a good idea to spool the turbo with out the engine running to provide oil to the bearings.
Old Feb 15, 2008 | 02:49 AM
chpmnsws6's Avatar
You can also use a smoke machine. If you invest in one, you can use it for exhaust leaks also. Hook it up, and anywhere you see smoke, you have a leak. You could always pour some smoke in the system, then pressurize it to see if you have a leak under pressure as connectors swell up (and they do...... ALOT under boost)
