2001 cummins turbo upgrade ?
Old Aug 22, 2010 | 10:35 AM
blue24valvecummins's Avatar
Default 2001 cummins turbo upgrade ?
hello i have a 2001 cummins and i am looking for a good turbo upgrade to replace the stock turbo. i have 150hp edge jammer injectors, stock turbo with bd boost elbow, edge comp, big honking air filter, 4 inch straight diamond eye exhaust, fass 95gph pump, 5 speed manual with south bend clutch rated at 400 hp. i would like to get around 425 to 450hp and keep it there. i have never had it on a dyno. is there anything else i need to do to get around 450hp, will a turbo upgrade help? how much would a good turbo cost and what should i look for? thanks
Old Aug 22, 2010 | 03:02 PM
biged681985's Avatar
a good turbo for ur setup would be a 62mm turbo, and would be around 1300-1800 bucks. and with ur current setup, should put ya in the 425-450hp range
Old Aug 22, 2010 | 03:18 PM
A Phat Shaft 62 would work very nice with your setup.
Luke
Old Aug 23, 2010 | 08:15 AM
thanks for the info where would be e good place to pick one up at?
Old Aug 23, 2010 | 10:26 PM
94cummins12v's Avatar
i have to say so as well im running the industrial injection super phat shaft 62/71/14 and love it for street use and towing
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
huntman7
8
Aug 28, 2015 05:42 PM
jd_clampit18
Feb 11, 2015 04:44 PM
Jan 28, 2015 03:30 AM
Oct 24, 2014 04:40 AM
