2nd gen 12v into 98+ Dodge Questions!
Old Aug 21, 2010 | 08:04 PM
Horns's Avatar
Default 2nd gen 12v into 98+ Dodge Questions!
taking a 98 or newer ram 2500 gasser and putting a 2nd gen 12v into it, how hard is the wiring? J/W if it's enough of a pain in that *** that putting it in a pre 98 would be easier.
Old Aug 21, 2010 | 08:17 PM
tiremann9669's Avatar
Early 98's came with a 12 valve, puttin it in any 2nd gen should be pretty easy
Old Aug 21, 2010 | 08:54 PM
Horns's Avatar
I'm just wondering how much harder it would be to put it in the 98+ trucks that would have come with the 24v.
Old Aug 22, 2010 | 12:10 AM
biged681985's Avatar
if it came with a 24v, it will all bolt right up as long as u have the 12v engine mounts. u will have to fab a few things up like the water temp, oil pressure, tach, altenator. and u will need to fab up a throttle using the existing one from the 24v.
if u were to put it in a truck that had the v8, u will have to rig up the frame mounts for the engine, a stouter transmission, and everything i listed above. if u want more details, pm me and ill give ya my number and tell ya more indepth.
Old Aug 22, 2010 | 03:28 PM
Horns's Avatar
Ok thankyou for the response.
Old Aug 22, 2010 | 03:46 PM
np man
Old Aug 27, 2010 | 06:06 PM
patrickdavina2's Avatar
I've got a question for you guys that seem to know more than me about this sort o thing. I'm doing this swap with an 01 that had a 24 valve . Already got the 12 in it and running but my problem is the alt and the tach Wong work. I'm new here and any help would be greatly appreciated
Old Aug 27, 2010 | 08:38 PM
I know it has to do with the Crank sensor, but I'm not sure what you have to do to correct it, hopefully somebody will have the answer
Old Aug 27, 2010 | 10:16 PM
on in 01 u will need to get ahold of schieds or one of the bigger shops to get the adapter for the cam sensor. they sale them for the guys p-pumping the 24v, but will work to get the tach working on the 01.
Old Aug 27, 2010 | 10:50 PM
Thanks and yes I got one from destroked came with a 12 sprocket wheel and a 2 wire sensor, have. Wire it every possible way and the tach will work for about twenty seconds the quits any ideas? Thanks
torino73
Apr 14, 2015 11:15 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
JMan96CTD
Jan 24, 2015 11:16 PM
JustAnother_cummins_guy
Wanted To Buy (WTB) - Used
Oct 21, 2014 05:35 PM
