Dana front axle
Old Aug 20, 2010 | 12:49 AM
Bigred7.3's Avatar
Default Dana front axle
Ok let me start off by telling y'all bout my front end set up on my 94 f250 4x4. The truck has a high pinion Dana 44 3/4 ton solid front axle and the rear is a sterling 10.25. The problem I'm having is that the gears in the front axle don't match the rear so with that in mind I can't lock her in 4x4. I'm debating on weather or not the Dana 44 solid is worth putting the right gears in it or if I should find a Dana 60 for the front. Keep in mind the truck has 39inch military tires. I need advice from y'all anything will help.
Old Aug 20, 2010 | 12:43 PM
93_Fummins's Avatar
I would find a Dana 60 merely for the load rating alone, and definitely for axle strength with 39" rolling stock...seems like a Dana 44 wouldn't be worth the trouble in terms of durability. But that's just me...
Old Aug 20, 2010 | 01:43 PM
cummins bronco's Avatar
yeah i would go with the Dana 60, it is more money up front but it will give you some peace of mind.
Old Aug 20, 2010 | 02:50 PM
Bigred7.3's Avatar
That's probably what I'll do. The Dana 44 I've got now is a a 3/4 ton that came out of a 70's f250. but the Dana 60 would b better for what I do.
Old Aug 25, 2010 | 06:50 PM
ETXBlueRam's Avatar
You'll be miles ahead with a Dana 60 in terms of strength and parts availability. About the only thing that 44 has going for it is it's an 8-lug. Throw big tires and a decent amount of horsepower to it, and it won't take much to break it. I had one in my '69 Cheverolet and it didn't last long even behind a stock big block with 36" tires.
Old Aug 26, 2010 | 11:45 PM
Bigred7.3's Avatar
Yea that's my problem I run 39s n the engine is soon to get bumped up so Dana 60 is a must
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
