lb7 head stud torque???
Old Aug 18, 2010 | 08:32 PM
bruno8's Avatar
Default lb7 head stud torque???
Just got my arp head studs @ was reading instructions on proper torque says to torque to 125lbs in 3 equal incriments 40,40,45? total 125-else where on this site it was posted to torque to 125lbs loosen torque to 125lbs3-4 times - what gives?
Old Aug 19, 2010 | 10:54 AM
K50's Avatar
K50
I would do the proper increments to 40ft-lbs, 80ft-lbs then 125ft-lbs in proper rotation around the head, then once you've torqued the last one up the remaining amount go around and make sure each one is at 125ft-lbs. As far as I know I thought this is just standard procedure
Old Aug 19, 2010 | 02:37 PM
2500HeavyDuty's Avatar
when i did mine it said to follow what they said to torque them down to.
i let them sit over night too after the second trq sequence and a few of them were a little loose.
Old Aug 19, 2010 | 07:54 PM
bruno8's Avatar
Default arp studs update
Talked with arp today -old stud kits that came with moly lube have a diff torque procedure- than the new kits that come with arp lube-note arp said there are alot of old kits out there.
gd1996
For Sale
May 15, 2015 09:42 AM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
Adam65
Jan 9, 2015 11:50 PM
twinturbo12v
10
Dec 8, 2014 07:58 PM
Oct 31, 2014 08:10 AM
