Fuel Gauge Install
Old Aug 17, 2010 | 02:39 PM
jumpnjed's Avatar
Default Fuel Gauge Install
Ive been doing some searches and cant seem to find what I was looking for. Is there someone out there that has detailed instructions on the fuel gauge install? I was hoping to find isntructions with pics and hopefully a parts list of what I would need. Any help would be greatly apprecialted... And also, do I need to run the gauge in the cab or could I just put one under the hood?
Old Aug 17, 2010 | 09:11 PM
95cumminsguy's Avatar
A fuel pressure gauge?
Old Aug 18, 2010 | 08:14 AM
jumpnjed's Avatar
yes the fuel pressure gauge... Shoulda clarified a lil better
Old Aug 18, 2010 | 07:06 PM
I hooked mine up to the port on the top of the fuel filter housing with a male x male adapter, ran stainless steel braided line to and isolater mounted on the fire wall then out of the isolater I run a 3/16 boost line to my guage in my pillar(you could put it under your hood if you wanted to i guess) but thats basically how you hook up any kind of fuel pressure gauge, I seen a kit on ebay that enables you to hook it up on the feed line to your injection pump, If you wanted to go that route. I got my kit from Diesel Manor, it came with a couple different adapters and such so hookin it up was simple
Old Aug 19, 2010 | 07:42 AM
jumpnjed's Avatar
Where did you mount yours at in the cab.. I have a a pillar pod but it is full. Just trying to figure out where to put another gauge without it looking hidious..
Old Aug 19, 2010 | 09:30 AM
rkadcock's Avatar
N.M. Bombers Director
I have my fuel pressure gauge mounted on my steering wheel column, it's not hidious looking but it does block 0-35 on my speedo. Or you can mount it under the dash by the 4x4 shifter
Old Aug 19, 2010 | 09:55 AM
jumpnjed's Avatar
I wish a company made a pillar pod that would mount on the passenger side.. Is there anything like that out there?
Old Aug 19, 2010 | 10:01 AM
rkadcock's Avatar
Gauges
You take their pillar mount and put it on the passenger side
Old Aug 19, 2010 | 10:42 AM
jumpnjed's Avatar
Thanks for the link rkadcock...
Old Aug 19, 2010 | 03:03 PM
tiremann9669's Avatar
You could mount it outside on the cowl if you wanted, you wouldnt need an Isolator that way.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
scottxmorris
Oct 8, 2014 02:14 PM
