fuel problem (im guessing) on my 96 powerstroke
Old Aug 14, 2010 | 11:29 PM
strokin it's Avatar
Default fuel problem (im guessing) on my 96 powerstroke
Okay I need to pick someones brain here for a second. I was heading to a ballgame lastnight when my truck started stuttering like it was running out of fuel and my fuel filter light came on. the truck died and I pulled over to the side of the road, lifted the hood and looked at the fuel filter (its brand new) and it didnt seem dirty or anything, so I tried to drain the fuel bowl and it wouldnt drain at all. also I noticed that my starter relay was smoking, there was a wire grounded out and I messed with the wires and everything was fine. I checked for codes and it said my CPS was bad, so I got one from autozone real quick and it ran just fine for a while. a few minutes later it did the same thing. it runs fine but when I get to higher speeds and RPMs it started acting like its not getting enough fuel and will died, but then I can start it again and drive off with little difficulty, but then after driving down the highway the fuel filter light will flash on and off then start slowly dying and lose speed.
also theres no fuel leaking anywhere, and no fuel in the valley
Last edited by strokin it; Aug 14, 2010 at 11:29 PM. Reason: Automerged Doublepost
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
Colby cummins
Nov 16, 2014 01:18 PM
